DS Crash with Stone Walls and Grounds
This discussion was created from comments split from: Fatal error message- what happened?.
  • edited May 2017
    I get those [error messages] too. I always trace them back to texture issues. Daz 4.8 was notorious for doing this to me. A new computer and 4.9 seems to have fixed the problems.. until I bought this last night: https://www.daz3d.com/stone-walls-and-grounds 5 minutes of iray spinning its wheels followed by a full program crash. Every texture, every time. Very upsetting. Now I'm running Nvidia 970 IIRC along with my i7. Running an MSI Apache Pro.
  • Richard HaseltineRichard Haseltine Posts: 111,348
    Is it the same error message (regarding a crash from ig75icd64.dll) or just a crash? It seems unlikely to be exactly the same issue so i have split this to a new thread.
  • Well, at least it wasn't deleted. Some relief.
    I'm currently running some experiments to see what can be done. Good news is that I have discovered by cutting off the cpu rendering default and just going with the 970 I've been able to actually get a few renders of it done. It takes about seven minutes to start iterations. I have only babystepped it to a single prop and shader so far.
    I'm wondering it these shader files are simply so big they are overloading the system. I was hoping to do some extensive repaints on some old props with these shaders. I'm gonna try it with two textures now and see wat happens.
  • Ok, that popped her! So I got access violation in ntdll.dll at 0033:000000001EA2F7DB RtlpUnWaitCriticalSection ()+747 byte(s)
  • lcfarlcfar Posts: 88
    I think the crash is due to the very high SubD level (12). Check out this thread https://www.daz3d.com/forums/discussion/74717/stone-walls-and-grounds-by-vikeike176/p1
    Thanks for the info. SubD 12.. explains a lot.. Anyone know how to trim that number? Never had to do it before.
