rerflection coming in blurry for plane geometric shape
When I use a plane I get low resolution blurry reflections for chrome or glass. When I use a higher polygon count item, the reflections come in clear. I'm not sure why I can't get clear reflections on the plane? Your help would be greatly appreciated.
    Is the effect you're describing in the final render, or is it in the assembly room?
  • edited December 1969
    The reflection comes in blurry in the render room.
  • 3DAGE3DAGE Posts: 3,321
    Hi Hunterdon1 :)
    In Carrara, you actually need to set an option to Enable "Blurry reflections" in the reflection shader,
    the default setting is Not blurry. (which is also faster)
    Can you post an image of what you're seeing, and also an image of your shader tree, with the reflection settings.
    See example :
    699 x 483 - 83K
    640 x 480 - 10K
