Can you copy a group of objects to use in the same render?
tkdroberttkdrobert Posts: 3,637
So I dressed up a pilot (G2M) and put him in an A-wing.  I then attached thrust effects to the engine.  I want to put another awing in the scene with another pilot and the same thrust effects.  How do I do that without haveing to so everything again.  I know that I can create presets, but that would still take some work.  It would be so much easier if I could copy and paste the one I already did. LOL  Is there a way to do that?
    The easiest way is to Save As > Scene Subset.  That lets you select which items to save and you can merge the whole thing into your scene as many times as you like.
  • tkdroberttkdrobert Posts: 3,637
    How do you merge?  I'll look for that option.
    By default, double-clicking on the icon for a Scene Subset in your Content Library will merge it.  You can also use File > Merge.
    OK I got it.  Thank you SO MUCH!
