Iray Wet Clothing Shader
an Iray shader that can make any clothing wet
  • nonesuch00nonesuch00 Posts: 18,897
    The iRay vol 2 shaders from MEC4D have a wet clothes preset (although I didn't particularly like the wet effect of it).
  • Beat578Beat578 Posts: 191
    Problem is that the Shader alone would not look realistic. Wet Cloth is heavy and tends to "glue" to the body. A normal looking shirt just with a wet shader would not do the trick. It has to be in combination with morphs, like the ones i saw in the "Boyfriend T-Shirt" product over at rendo.
  • EcVh0EcVh0 Posts: 535
    This is in my todo list :) but need to work on Cloth Shader 2.0 first XD
  • kaotkblisskaotkbliss Posts: 2,918
    Autofit already does this LOL
  • Blind OwlBlind Owl Posts: 504
    Too true. I've spent a lot of money trying to unglue it.
    But yes, if a decent (or indecent) wet clothing shader was available I'd probably spend more money to have it.
    Exactly :D
  • chrbou2001chrbou2001 Posts: 120
    Wow, i would be impressed (and a sure buy)!
  • nomad-ads_8ecd56922enomad-ads_8ecd56922e Posts: 2,020
    edited July 2017
    I'd buy it too.
    A particular feature I'd also hope would be in it would be the ability to selectively make only part of the garment wet... say, like what happens when someone spills a drink on someone's lap.  It'd also be more realistic if, with at least some fabrics, the wet part of the garment then became partly see-through, but also of course it'd make sense if the wet part of the germent changed color wrt what sort of fluid it had been splatted with.
    It'd also make sense to be able to progressively make the wet spot grow bigger and spread as desired across the surface... say, if some character was slowly bleeding into their clothes.
    Post edited by nomad-ads_8ecd56922e on
  • IsaacNewtonIsaacNewton Posts: 1,300
    I'd buy it too.
    I like the idea of the wet part of the clothing becoming partly see through (Wet T-shirt competition, here we come), however that would need to be optional as most materials do not become see-through when wet (eg denim), it's mostly white cotton, some lycras and silks.
  • I Can't agree more...wet clothing shader is overdue. thanks in advance!!
  • Richard HaseltineRichard Haseltine Posts: 112,049
    edited August 2017
    Wetness is more than just a material settings - wet fabric behaves diffrently (it sticks to the skin, or its creases stick to themselves, while the added weight causes the unstuck portions to hang more vertically). A shader alone really won't do the job. (Oops, I see this has already been said.)
