Dformer question - multiple dformers cause crash?- solved
FrankTheTankFrankTheTank Posts: 1,624
I have a piece of clothing that I added a deformer to, and everything worked fine. Then for a different scene I needed to add a 2nd dformer to the same piece of clothing and when I tried to "add Map" under the influence weights, Daz Studio immediately crashed. Am I using Dformers wrong? Am I only supposed to use one Dformer per item?
I was following this tutorial and it worked great for one dformer, but can't seem to add a 2nd without crashing.
http://slimmckenzie.deviantart.com/journal/Tutorial-D-former-with-Node-Weight-Map-Brush-609397848
Post edited by FrankTheTank on
  • Richard HaseltineRichard Haseltine Posts: 111,332
    I'm not seeing this in 4.9.3.166 using a primitive to test.
  • FrankTheTankFrankTheTank Posts: 1,624
    When I restarted DS after the crash, I was able to add a second Dformer. The only thing I did different was I made sure that "respect selection" was checked, whereas the first time I forgot to select that. Not sure if that caused the crash or not. But I'll say its solved for now at least.
    392 x 976 - 37K
    I have it unchecked and no crash. Did you get more than one crash? If not it may just have been a transient glitch on your system.
    Well it hung up once and I forced it to quit. The 2nd time it crashed outright. But then worked the third time. So maybe things didn't really clear out after the 1st hangup. Probably like you said just a transient glitch. I'm rendering now so can't do any more tests but I'll mark the thread solved.
