[Solved] Skin Issue OZBD Poppie for Aiko 7
Hello,
I load "OZBD Poppie for Aiko 7" into my Scene, do not any morphs or other stuff and get this ugly line between torso and arms!
Checked the surfaces, all options on torso and arms are the same and both a iray uber shaders.
Is there anything I dont know or do wrong?
Maybe someone can help me...
511 x 403 - 310K
Post edited by DeputyFreddy on
I believe this is a case of the gamma for one of the glossy maps being different than the others. Try clicking on the Torso surface, then click on the image map for either Glossy Layered Weight or Glossy Color (depending on where the artist placed it) and then go up to Image Editor (not Layered Image Editor). In the popup, the gamma should be set to 1. If it is, then it's likely the arms which have the wrong gamma setting.
Thanks man, you was totally right!
Surfaces --> Arms --> Glossy Layered Weight --> Image Editor or Layered Image Editor --> Image Gamma from 0 to 1 --> Done, no more ugly line between torso and arms!
