GeForce Driver 382.33
RSand55
Hey Guys:
I updated from 378.78 which was working fine with Daz to Ver. 382.33 (via the GeForce Experience).
Everything seemed fine until I attempted to launch Daz. After the splash screen loaded, it would
get to the "building interface" line then crash to the error seen in the attached pic. I looked through
some threads here and one advised rolling back the driver through Windows 10 which I did.
Now Daz is working. Anyone else having this problem with the new driver?
Thanks.
Robert
686 x 514 - 98K
I just installed 382.33 manually last night and it seems to work fine. I was previously using 382.05 and before that 378.92, which both also worked. I have a GTX 960 card...
Very strange. Perhaps a bad installation on my part.
Appreciate your comment.
I was using 382.05 , then tried to up-date driver to 382.33 from GeForce Experience as same as you. but I failed install driver twice with custom and clean install option.
(I use this option, though it is not best to clean up-date driver,,)
I think Geforce experience seems not stable, then I un-install Geforce experience by controll panell, then re-start my pc,
and dowonload Geforce experience from nvidia , and try to install geforce experience, but I saw erroer message, alerady another aprication working,
then check task manager, there seems some Nvidia service still wroking on my pc, (why? I do not know,, I just un-install, and re-start windows 10 pc,,)
I shut down two Nvidia service from task manager.
after that I could install Nvidia experience, then could up-date driver. I feel, geforce experience often cause some problem up-date driver correctly.
Interesting. I wonder if installing the drivers manually without Geforce Experience would be better.
That's the way I did it in the past.
I've only experienced issues with nVidia drivers if I've tried to set up a custom application profile for DAZ Studio in the nVidia control panel.
