Restored from back up but content library is messed up
SassanikSassanik Posts: 340
Okay I had to do a full system restore, and had my Daz stuff backed up, all my Daz 3D> Studio> folders were put back in the same spots.
I re-installed Daz Studio 4.5 but it is not showing up in my smart content folders and stuff that has metadata and should have installed correctly in the first place.
Am I missing a file somewhere? Or a setting?
Thanks!
Amy
    Click on the drop down menu in the Content Library pane, and select Content DB Maintenance, then Re-import Metadata, that may help.
  • SassanikSassanik Posts: 340
    I did that, and it doesn't seem to have re imported everything. Is there a file that I can pull from back up and replace a current one with? Is there a folder where the metadata was stored?
    Amy
  • 3Ddreamer3Ddreamer Posts: 1,357
    edited February 2013
    Did you stop the Content Manager while you copied back your user data in C:\Program Files\DAZ 3D\Content Management Service\databases ? I restored a backup on Friday and 'lost' my Content Library Categories. I stopped CMS copied the filed back again started CMS, and it worked. That restored the Smart Content Metadata as well which I don't use. Hope that works for you
    Post edited by 3Ddreamer on
    I can see the folder you are talking about, but not the database file/folder. Do I need to replace the content management server application file?
    Amy
    914 x 670 - 200K
    You should have a 'databases' foler in there as I have, shown below. I wonder where yours could be.
    Are you using the 32 bit version? If so, you may have to look in Program Files (x86) instead.
    808 x 452 - 186K
    I am using 64 bit, but don't see a content management service window under the Programs Files x86 Daz folder.
    Very strange!
    Amy
    The one i showed you is my 64 bit folder, that is where yours should be as well i think, the screenshot you posted doean't incude the databases folder, but mine does. I am using DS 4.5.1.56 64 bit
    What version of DAZ Studio are you running? Help > About DAZ Studio
    I am running 4.5.1.56 on Win Vista.
    Amy
    Hi,,
    In my case,,
    database is under the C:\ProgramData\DAZ 3D\Content Management Service
    then CMS aprication is under the C:\Program Files\DAZ 3D
    I do not know,, why the difference happen from Jimmy,,,
    but you may find database of CMS under programdata folda,, I think.
    windows 7 64 bit version.
    daz studio 4.5.1.56
    if now daz CMS database should be installed in program files,,
    I had not uninstalled corerctly CMS when version up ds, (many times version up,, last year,,)
    I may need to re install CMS,,, :down: (no hope,,,reinstall again,,)
    and,, you can check your database path, by ContentManagementServer.ini file.
    I can see, in pic,, you have the ContentManagementServer.ini file
    where your CMS.exe is installed.
    open it by text editor,
    then check,,
    SystemCatalog=C:\ProgramData\DAZ 3D\Content Management Service\databases
    521 x 553 - 62K
    I found my database, and it is under Program Data, not under the program files.
    It should be under program files?
    Do a uninstall and reinstall? To get it in the right spot? I am afraid that the Program Data folder was not saved in the backup, but I will have to double check that. Its going to be VERY frustrating if I lost all my content settings.
    Amy
