Applying puppeteer, expression and cloth problem
samialshahrisamialshahri Posts: 0
-shown in the 1st picture when I try to apply cloth from the bottom right side on to the model this is what would happen(the mid section and tights becomes invisible).
-on 2nd picture when I try to apply Freak 4 on the right bottom to a basic male or shaped M4 doesn't do any changes same thing with facial expressions.
how do I solve this?
758 x 390 - 53K
661 x 507 - 85K
  • Richard HaseltineRichard Haseltine Posts: 112,009
    edited February 2013
    The first files are material presets - you need the clothing models loaded and selected, then you apply the presets to those and not to the base figure.
    The second are poses for Freak 4, I'm not sure what they do but if it involves the morphs that make Freak 4 Freak 4 they won't work on Genesis. In any event, you'd need the Puppeteer pane (Window>Panes(Tabs>Puppeteer) open to use the result.
  • samialshahrisamialshahri Posts: 0
    thanks I figured whats wrong here. don't got a required item.
    Post edited by samialshahri on
    do I need poser 6 to get M4 base activated or installed? I know without M4 you can't use any of F4 stuffs
    No, Michael 4 works in DAZ Studio.
