the Blinn and the Phong? for the Duckster's eyes
Mistara
lookin for highlight types.
is there a dropdown for types somewhere?
how would i make a roundish highlight on a sphere?
thanks
Post edited by Mistara on
wanted to put some blinn on the duckster's eyes.
Blinn shading is a subtle variation on Phong shading. The most noticeable difference is that highlights appear rounder. In general, you don't need to use the Soften parameter (described in Blinn, Oren-Nayar-Blinn, and Phong Highlights) as often as you do with Phong shading.
bing found
https://www.daz3d.com/forums/discussion/113511/shader-creating-settings-for-carrara-q-a-come-one-come-all/p2
should be able to use color gradient to make a rainbow colored volumetric cloud or fog?
roygbiv
lol- this not it
For a Shader I would try using something other than Color beneath your Color Gradient. For instanstance... a Noise function... even Fractal Noise can spread out the different colors over the object... I've not ended up with a rainbow tho... also if the Noise, Turbulance or whatever you choose has a "fractal" option this can be turned on to create better blending between the colors of your gradient. Sometimes I'll even change the Gradient by making it a mixer just to complicate things. Still I haven't gotten results I'm trying to get... sure fun trying tho... if I come up with something I'll post it to my Shaders in Carrara thread.
BTW: I've finished the CarrarArtist Logo... it's posted to the main Carrara discussion under that name.
