Freezing or baking bone position?
ScavengerScavenger Posts: 2,677
Playing around with something...I've moved the head into a specific position that I want it to be where it's suppsoed to be.  I've locked and limted it, but when I do ERC controls, they keep detecting the position as a change, not as the default...how can I make it the "defualt"?
218 x 251 - 24K
  • Jim_1831252Jim_1831252 Posts: 728
    Could you pose then use the joint editor to memorize the current location? I'm a bit of a noob at these things, but that's something I'd try.
  • Richard HaseltineRichard Haseltine Posts: 111,473
    You could add a constant to the ERC tocompensate, depending on the link type used. You could also create a hidden, locked proeprty and add that (with a suitable multiplier) via a second ERC link.
  • ScavengerScavenger Posts: 2,677
    Well, I click them off to not include them in the erc.
    ERC Freeze is fine for basic links, but for more advanced options you need to use the Property Hierarchy - I just replied to your other thread with an example of doing that.
    Ok. I'll add some stuff there as lots of things are coming together..or not.. thanks.
