making duplicates of a propset to build a larger set
Could use some help with this..
Using the Petipet hangar A -  I would like to increase the length of the hangar to include 8 launch bays.
In the package I do have a propset that is one complete hangar bay.
Is there a way to copy the single bay prop then affix/attach to the original bay and extend the bays in such fashion.
I can do this very easily in Iclone, but I'm pretty well lost as far as doing this in Daz3d studio.
I suspect copy and grouping may be the answer, but I'm not sure how to do that.
https://www.daz3d.com/sci-fi-hanger-a
    If you are using it in DS, then you can create instances of an object or group. Works great for multiple objects and saves on resources also.
  • SerumSerum Posts: 257
    you can create instances but if you create too many you need to remember to switch your render settings from optimized for speed to optimized for memory
    (not sure if it applies to 3DL i just dont use that but for sure in Iray)
