Export MDD in silent mode : how to list arguments
hello,
I was looking for an MDD Exporter but it looks like there's not such a class existing so I can't use findExporterByClassName command
I try to export an MDD file without dialog but I always have one popping and I don't know which argument the exporter could use
I would like to list the arguments I can pass to the exporter with MDD files but I don't know how to do
I have used the exporter example of the daz help like this :
/********************************************************************** Copyright (C) 2002-2017 Daz 3D, Inc. All Rights Reserved. This script is provided as part of the Daz Script Documentation. The contents of this script, and\or any portion thereof, may only be used in accordance with the following license: Creative Commons Attribution 3.0 Unported (CC BY 3.0) - http://creativecommons.org/licenses/by/3.0 To contact Daz 3D or for more information about Daz Script visit the Daz 3D website: - http://www.daz3d.com **********************************************************************/// Source: http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/export_obj_silent/start// Define an anonymous function;// serves as our main loop,// limits the scope of variables(function(){ // Get the primary selection to use for the file name var oNode = Scene.getPrimarySelection(); // If something is selected if( oNode ){ // Get the node's skeleton var oSkeleton = oNode.getSkeleton(); // If it has a skeleton if( oSkeleton ) { // That is the node we want for the name oNode = oSkeleton; } } // Get the export manager var oExportMgr = App.getExportMgr(); // Define the class name the for Wavefront Object (*.obj) exporter var sPath = "b:/temp/test.mdd"; // Find the exporter var oExporter = oExportMgr.findExporter( sPath ); // If the exporter exists if( oExporter ){ // Create a settings object var oSettings = new DzFileIOSettings(); // Fill the settings object with the default options from the exporter //oExporter.getDefaultOptions( oSettings ); // Define whether or not to show options var bShowOptions = true; // Define whether or not to show options before prompting for a path; // requires 4.9.3.22 or later var bOptionsBeforeFile = (bShowOptions && App.version64 >= 0x0004000900030016); // Get the options for the exporter if( !oExporter.getOptions( oSettings, bShowOptions && bOptionsBeforeFile, "" ) ){ // We're done... return; } // Debug print( oSettings.toJsonString() ); // Set the desired settings for the exporter oSettings.setStringValue( "Preset", "LightWave" ); // If the version is 4.9.3.22 or newer if( App.version64 >= 0x0004000900030016 ){ // Do not collapse UVs Tiles oSettings.setBoolValue( "CollapseUVTiles", false ); // Show individual settings in the dialog oSettings.setBoolValue( "ShowIndividualSettings", true ); } // Define whether or not to show the options after prompting for a file oSettings.setIntValue( "RunSilent", (bShowOptions && !bOptionsBeforeFile ? 0 : 1) ); // Debug print( oSettings.toJsonString() ); // If the user didn't cancel and the file doesn't already // exist, or the user wants to overwrite it if( sPath && MainWindow.checkExistingFile( sPath ) ){ // Write the file using the options specified oExporter.writeFile( sPath, oSettings ); } // Clean up; don't leak memory oExporter.deleteLater(); // We didn't find an exporter with the class name we wanted } else { // Inform the user MessageBox.critical( qsTr("An exporter with the class name \"%1\" " + "could not be found.").arg( sClassName ), qsTr("Critical Error"), qsTr("&OK") ); } // Finalize the function and invoke})();thanks
Post edited by ratus69_c6741fefbf on
