Transferring D-former morphs?
Hi all, once I spawned a D-former morph for a figure, is it possible to transfer it to clothes to make them fit over the morph? thanks.
  • Richard HaseltineRichard Haseltine Posts: 111,348
    For a Genesis figure that should happen automatically when the morph is applied to the figure - if it doesn't, click the gear icon on the morph's slider, Parameter Settings, and make sure AutoFollow is checked. For earlier figures using the parametric rigging system (Victoria 4 etc.) right-click the figure and select Transfer Active Morphs; if that doesn't work, again check AutoFollow is on
  • Thanks for the fast reply, I work with G2F but unfortunately autofollow doesn't work.
  • my bad, I just deleted the cloth, and if I fit the same one AFTER creating the morphs it transfers correctly.
    Fitting it to None, then back to the figure should also work.
