Merging Faces
Suppose I splite a face into 2 by adding a line in the middle? Which tool would I use to remove the line to make it one whole face? If I just remove the middle line, then the entire face is deleted because that middle line is essential to both faces? Sorry if this is a newb question.
So as you can see, the glass was split into two. I did this because the backpart of the lumia920 is rounded, not flat. But in doing that, it created a split on the front.
Are you trying to remove the middle line ? If so select it, then loop it (letter L is the keyboard shortcut) then press the backspace key, when the option box appears choose ALL.
Looking at your sceen grab I can see you are going to have problems with Ngons. Normally, a face will have 4 points.
Rather than try to put into words I've done a quick video for you, the Command Viewer will tell you what tools I am using.
Note - I included the Backspace option so you can see that in operation aswell.
https://youtu.be/4YAJxZoyxCQ
Hope this helps, if not please feel free to PM me with the prop and I'll see if I can fix it for you - John
