[Resolved] Missing Objects
FuerchanFuerchan Posts: 63
Hello,
When I open one of my DS objects I have this message :
Joint [MissingObject 01.jpg]
Then I rename the folder "Objectsperso", but I have this message:
How do I open my objects from the "! Perso" folder ?
Thank you ;-)
F.
503 x 422 - 22K
519 x 126 - 18K
Post edited by Fuerchan on
  • Richard HaseltineRichard Haseltine Posts: 112,347
    Could you go into a bit more detail about what you are doing please.
  • FuerchanFuerchan Posts: 63
    Hello,
    I created objects in 3D.
    Then, to use them as asset, I saved these objects in a folder in "My Libary", called "! Perso" and in formats:
    - Scene
    - Scene SubSet
    - Installation Presets
    Since then, I had to rename the file, in the past, I do not remember (...). And the link is no longer anywhere.
    And, even if I rename my source folder as requested in the error message, this does not solve the problem but created another one (Message 2).
    Thank you
    F.
    The error is not asking you to rename your source folder - it is telling you it can't find the files. Did you use File>Save as>Support Asset>Figure prop Asset (or Sceen Assets), or did you just save as a scene file? Where is the OBJ file - somewhere in My Library or still in another location?
    Hello,
    The fjier obj is placed in:! Perso / weapons / bacrone / ke 0300.obj
    But DS seeks it in:! Objectsperso / weapons / bacrone / ke 0300.obj
    It would be necessary to modify the path of obj (if possible) so that DS will look for the object in:! Perso / weapons / bacrone / ke 0300.obj
    If possible, how?
    Thank you
    F.
    The path is stored in the .duf file - could you upload that (either attach it to a post or put it up on Dropbox or the like and post a link).
    Hello,
    Here is the .duf file.
    Thank you
    F.
    If you unzip the .duf file (I used 7Zip, but you can use the batch Convert pane in DS) and open it in a text editor you can find and correct the path  -for example, in your file it's one line 847
    						"id" : "KE 0300-2",						"url" : "/data/auto_adapted/KE%200300_885/geometry_7443157f_cbf2_a45f_f75b_28bae6bb4f9c/KE%200300.dsf#KE%200300",						"name" : "KE 0300_885",						"label" : "KE 0300",						"type" : "polygon_mesh",						"legacy_source_info" : {							"location" : "/!ObjectsPerso/Armes/Bacrone/KE 0300.obj",							"settings" : {
    So presumably to match your existing folder names you need to edit it to
    						"id" : "KE 0300-2",						"url" : "/data/auto_adapted/KE%200300_885/geometry_7443157f_cbf2_a45f_f75b_28bae6bb4f9c/KE%200300.dsf#KE%200300",						"name" : "KE 0300_885",						"label" : "KE 0300",						"type" : "polygon_mesh",						"legacy_source_info" : {							"location" : "/!Perso/Armes/Bacrone/KE 0300.obj",							"settings" : {
    The extract above also shows that the converted files DS initally looks for are in  /data/auto_adapted/KE%200300_885/geometry_7443157f_cbf2_a45f_f75b_28bae6bb4f9c/
    Hello,
    I made the changes in the .duf file (I placed the .obj file in an appropriate folder) and writing this:
    Perso \ Weapons \ Bacrone \ Obj \ KE 0300.obj
    But now another error message appears when I want to insert the object to the scene.
    Also, I do not have a KE 03200 file in / data / auto_adapted / ...
    Does this error come from there?
    Thank you
    F.
    You need to use / not \ as the folder separator in the .duf file - did you?
    Hello
    Indeed, the problem came from there. I was able to recover a good part of my objects.
    Other problems arise ... But one thing at a time ... It will make another subject, perhaps ...
    Thanks for the help.
    F.
