V4 clothing content not loading..
SamanthieSamanthie Posts: 308
I am having more than one issue with Daz Studio 9 this morning. I can't seem to load any of V4 clothing. I recently purchased the Skadi outfit and although that loads fine I discovered none of the other items I purchased clothing wise for V4 will load. They are there in content library tab but when I click nothing happens, right click and load doesn't work either. V4 is selected in the scene. The items are in color not greyed out. The other thing is an item I purchased a long time ago called Feathered Wings. I installed them 3 times through DIM and although they are in the path where DIM put them they are not found in studio.  Searching pulled up nothing. I finally had to uninstall them (don't like duplicates) and reinstall them with Daz Connect. They work now but why didn't they show up as they should have and why did I have to resort to Daz Connect? I don't want to have to reinstall everything again. I just did that on this new pc. I want this to be streamlined.
*edit Some other content is missing as well. I appreciate any help but maybe it would be better to just reinstall everything with Daz Connect.
Post edited by Samanthie on
  • SamanthieSamanthie Posts: 308
    Just discovered I was clicking on MAT files.lol It has been awhile working with the program. Still doesn't explain how Feathered Wings was not seen at all by Daz even though installed by DIM.
  • Richard HaseltineRichard Haseltine Posts: 112,049
    Where were you looking? Content Library pane Poser Formats>Install folder>Library type>some folder is always the fall-back, if it isn't there then soemthing went wrong.
    I was looking under Content Library tab. I think I have figured this out. After my mistake with the MAT files I still wasn't able to find the actual clothing items so I went into the content directory manager. I looked over the directories listed but noticed I only had one listed under Poser Formats. So on a hunch I added the My Library directory under Poser Formats and that seems to have worked. I found V4 clothing and have been working on a new scene this afternoon. Just now I reinstalled Feathered Wings from DIM and there they are. I can now uninstall the connect version if I want.
