Does DAZ Studio support macros?
SloshSlosh Posts: 2,391
I am trying to automate something in DAZ Studio and wonder how to go about it. From what I understand, scripts can be written for this purpose, but I can't find any documentation on how to write them. I would like a script or macro that would allow me to change the UV set on Genesis when applying a Generation 4 texture without having to go into the Surfaces Tab and change it manually. I would then like to assign that script or macro to a hotkey, or at least list it as a Preset in my Smart Content Tab.
Does something like this already exist, or can someone direct me how to go about writing my own?
  • Richard HaseltineRichard Haseltine Posts: 111,945
    The simplest way to do this would be to save a materials preset, expanding each entry in the options dialogue so that only the UV set is selected. Otherwise, a script could do it - save a Materials preset from the File>Save as>Deprecated sub-menu in .dsa format and opening that in the Script IDE (Window>Panes(Tabs)>Script IDE) should give you an idea of how to do it - indeed you could just edit the script created.
  • SloshSlosh Posts: 2,391
    That was brilliant, Richard! I went with the first idea... I haven't done any scripting in Daz Studio before, and although it reminds me of Visual Basic, I am very rusty (10 years) on writing that, too. The material preset works like a charm. Thank you so much! Now, I just have to figure out a way to assign a hotkey or something to it. Is there no way to put an icon on the interface for it? Doesn't matter, this will work great. Thanks again.
  • ReDaveReDave Posts: 815
    Once you have your preset saved, locate it in your Content library inside DS, then right click on it and select "Create Custom Action". That will create a Scripts entry on the menu bar. You should then be able to assign a shortcut key to it by going to Window->Workspace->Customize: on the left pane, named "Actions", at the top it should have an entry named "Custom" where you will find your preset which can be assigned a shortcut to now. Be aware that reinstalling DS will remove the Scripts menu but not the Customize entry.
