Will old content installers work after DLM is installed?
SkyshorrSkyshorr Posts: 28
Hi folks, I have purchased and saved a lot of Daz products onto MEM Sticks.
I have not needed to use many of them yet, therefore am concerned that if I switch to DLM I will not be able to load theses products.
Plus, I value Daz and my computer ( Plus I need to concentrate when I learn a program) so much, that I will not have a web connection at home.
I come to this Net Cafe, sign in and have stored my products on Sticks then loaded them at home.
Is that method no longer an option?
  • TotteTotte Posts: 15,279
    With DIM you can download (without installing, and then install back home.
    You can even have a DIM at home then copy the downloaded files from your coffee shop DIM to your home DIM (zip +manifest), then install those you want.
    And you can still run your old installers but then you need to take in account not installing the same via DIM, but I recommend using DIM as then you will have the latest update which is specially important with genesis content as there has been many updates to those.
