Glute and Breast Movement for Genesis Install
Hi all, purchased a
and cant install.
(after install, cant see morphs on DS)
My software folder:
B:\Program Files (x86)\DAZ 3D\DAZStudio4
My stuff folder:
B:\DAZ 3D\Studio\content
Daz version: 4.0.3.47
Any here can help-me solve it?
tHANK yOU
    Radaeli said:
    Hi all, purchased a
    and cant install.
    My software folder:
    My stuff folder:
    tHANK yOU
    If you are still installing into a folder called Content, is that the path that you gave the installer? If os, I would look inside the Content folder to see if there is one called My Library, and move all of it's contents directly into the Content folder (up one level in other words), that is also assuming that is where you installed your Genesis content to.
    The default folder for content is now called My Library in DS4 and above, and it is the new name for the DS3 Content folder, so they should be treated as one and the same. If you are going to use the DIM to install in the future, there is yet another new default location for content.
  • edited December 1969
    hI...
    Have no "My Content folder name" just, "B:\DAZ 3D\Studio\content\Runtime"
    Maybe, need install new 4.5 daz version, but, i dont like new version ... :(
    I go try it
    I just checked this item, and it needs DS4.5 to work anyway.
  • edited February 2013
    Thank you..
    See, you can help-me again?
    I have stuff on B:\DAZ 3D\Studio\content
    How to backup it?
    I have older projects with Genesis and victoria and need open with 4.5 daz version.
    You can explain to me: I did not understand much about folders and back ups on DS.
    Thank You
    I installed DS 4.5 but, the problem persist, morphs cant load.
    Post edited by msn.vgs_78ad20bf53 on
    The important folder so save, if you want to open saved scene files again, is the 'data' folder.
    Just make sure that it is included in any backups that you do. It should be inside the Content folder, but just make sure of that before you back it up.
    Morphs for Genesis, need to be installed into the same folder that you installed Genesis into. Genesis is part of the Genesis Starter Essentials file that you downloaded when installing DS4 or DS4.5.
    Where did you install it to? What path did you give to the installer, and can you load and use Genesis, and the items that come with it?
    I dont remember folder name, i think is B:\DAZ 3D\Studio\content\data\DAZ 3D\Genesis\Base\Morphs\DAZ 3D
  • fixmypcmikefixmypcmike Posts: 19,735
    Your install path should be B:\DAZ 3D\Studio\Content, never deeper than that.
    Did you install Genesis Starter Essentials when you upgraded to DS4.5?
    Thank you for reply...
    I make a new download of genesis and ds 4.5 and removed all older stuff, but, genesis glutes and breast product cant show on DS.
    See my folder
    1280 x 720 - 206K
    You wont find any icons for loading these morphs, they are ONLY shapes for Genesis. The Product page says :
    •This product contains only new shapes for Genesis, there are no user-facing files.
    These items appear on the Shaping tab as sliders, or if you don;t use the Shaping tab, select Genesis, then go to the Parameters pane, select 'All' and the use the search funtion to find 'Twist X' or 'Twist Y' you should find them there.
    Post edited by JimmyC_2009 on
    Solved!
    Hey, thank you for help, now i can use morphs, thanks!!!
  • joe_96cb244b30joe_96cb244b30 Posts: 0
    Hi,
    I have also purchased and installed the G&B Movement set. I'm running Daz Studio 4.5.1.6 and I have confirmed the files are in the correct location, ie.
    C:\Users\pc\Documents\DAZ 3D\Studio\My Library\data\DAZ 3D\Genesis\Base\Morphs\Zev0\G&B Movement
    It should be noted I also have the Aging and Dental Plan morphs by the same author, and can be located just fine in the Shape Editor
    However, so some reason I cannot locate any of the G&B Movement morphs. I have selected Genesis, selected ALL from the shaping tab, types in a variety of the morph names (LB, Twist, etc) but with no results. Also looked under Torso, etc, and well as slowly worked my way through the list of ALL morphs looking for the G&B set.
    I strongly suspect I've done something fundamentally stupid, but being stupid, can't see it. Where should I be looking?
    Best regards,
    Joe
    Hi,, dev zero released these morphs as genesis poze controlls assigned root node.
    (I do not know wihich is better,, shaping or pozing,, )
    so that you may need to select genesis root, then go to pozing tab.
    Pose Controls/Torso/G&B Movement secttion. you must find them.
    if you select other node, these morphs can not be shown in pozing tab.
    but in parameter tab, you can see all morphs.
    I sometimes feel trouble to find , which is poze controll morph or which is shaping morphs.
    there seems no perfect rule . so vendor use them as they feel like. I understand it.
    but basically,, they may need to assign controller or morphs to correct node or region group.
    if make poze controll for breast, or hand or legs.
    they may better to assgine them to each node, not genesis root.
    so that, when I use universal tool, then select node,, I can easy serch these morphs.
    (eg when I select genesis head, genesis expression poze controller visible)
  • I'm having similar issues here just installed and I don't see any changes under Pose Controls > Torso. There is no G&B Movement section created. I'm trying to reinstall by uninstalling Genesis and GB, then reinstalling both.
