Poser 12 Compatibility
homicidal45homicidal45 Posts: 0
edited February 2013 in New Users
Will V4 work on a new PC with Poser 12 AND Windows 8 running at 64 bit?
Post edited by homicidal45 on
  • frank0314frank0314 Posts: 15,116
    Do you mean Poser 2012? Yes V4 will work in it and Windows 8
  • homicidal45homicidal45 Posts: 0
    Hi there,
    Yes Poser 2012.. I cannot seem to get her to load..
    The PC is showing after I run through the loading set up, this...
    Error reading INI file C: /Program Files (86)/Common Files/Daz/dzInstall.ini The application will exit now.
    Then it closes the program.. I have tried both Poser and DAZ setting to load (it gives a choice.. Both times same thing..
  • Richard HaseltineRichard Haseltine Posts: 112,003
    Try installing the free Emotiguy - that should generate a DzInstall.ini file
