Male Abs Help
David-17David-17 Posts: 30
edited May 2017 in The Commons
Hey all you great Artists :) I hope someone can help me out and give me suggestions about this sexy guys abs here. I want them to look a bit more realistic. Difined and visible, but not so strange like now. Hope you see what I mean. Yeah, there are troubles with his arm hair also, but I didn't check about it yet.
You need to know what I used, right? The Character is Felipe and as for the body morphs I have almost everything I guess, like Shape Shift, Muscularity Morphs and so on.. all for Genesis 3 males.
1000 x 1000 - 2M
Post edited by David-17 on
  • xyer0xyer0 Posts: 6,516
    edited May 2017
    Hi David-17, I would suggest using a different skin (something from Raiya, Saiyaness, or [Daz ] 7 core models (other than Leo) if you want photorealism. FW skins, to my eyes, look more Photoshopped than photorealistic. If you have Lee 7 HD Add-Ons, they would look really good, but I immediately saw the skin as the issue, not the morphs.
    Post edited by xyer0 on
    There are morphs I've found at other stores which make less symmetrical abs.
  • David-17David-17 Posts: 30
    Hello xyer0 and Serene, thank you both. I'm going to test both options.
    Trying Lee HD body and skin. After playing with some sliders I think it's getting better.
    1000 x 1000 - 2M
    1000 x 1000 - 2M
  • IldanachIldanach Posts: 217
    Felipe is a great character. While morphs etc are great for adding realism, I think the skin texture and shaders play a huge part in it too. Here's a version of Felipe I've been playing around with. Still has a bit of work to go...
    edited May 2017
    Pretty sexy. What body hair are you using Ildanach? Is that the original skin?
    Below an other test. Still al lot to do I guess :)
    1000 x 1000 - 1M
    Cheers! Still not finished it yet, need to fix up a few things on it.
    Your latest test looks much better. Good job!
    Yeah, it's the original Felipe skin. I made some adjustments in Photoshop and used shaders though. The hair is OhMyBodyHair.
    Ah the OhMyBodyHair. I'm using that one too.
    I made some adjustments. Reduced the veins and muscles a bit. Minor changes on the Abs.. guess it's okee like that? Or anny changes suggested? Also removed some of his leg hair and added better lightning.
    1000 x 1000 - 1M
