Diahme Hair
AnInnerEyeAnInnerEye Posts: 23
Just want to give everyone a head's up on the Diahme Hair. Don't bother downloadling it for Daz Studio as the morphs, hair actor doesn't show up. only the textures. Used DIM to install it, also installed it manually. It can only be a working item in Poser.
Just wanted to mention this as I created it.
Thanks, Catherine Todd.
Post edited by AnInnerEye on
  • SixDsSixDs Posts: 2,384
    Actually, Catherine, it does work in DAZ Studio. To find the morphs you need to have the 'neck' node for the hair selected in the scene tab - voila! They are all there and work fine.
  • Richard HaseltineRichard Haseltine Posts: 112,059
    edited May 2017
    Did you download and install both parts? As with many older items, it has an installer for the Poser version (object, morphs, and textures) plus a second for the DS materials - to use in DS, load the Poser hair and apply the DS materials preset. The Connect version gives all of the files in one go, and seems to load OK.
  • AnInnerEyeAnInnerEye Posts: 23
    Richard I did...but I cannot find the actor, only the textures. And I've search via Product, Daz Library, Poser Library. The reason I really did want to get it working so I could do an updated version for some of the new characters, with new textures and more...
    Try try try again ;)
    Thanks to you both for answering!
    Still no actor or hair to be found, just the textures...bleh
    It should be in Poser Formats>folder installed to>aie3d>diahme hair (lower case letters here because that's a Connect install, so fo me it's Poser Formats>Daz Connect>aie3d>diahme hair
    I uninstalled it through the Install Manager, then re-installed it and now its there!
    Thanks, Richard! laugh
    Glad it's working now.
