Back to Basics Tutorials Installing DS4 and more ?
MarcuseMarcuse Posts: 0
Complete beginner to 3D so apologies in advance, but I'm trying to follow the "Back to Basics Tutorials Installing DS4 and more" (see link) but I'm unable to tell which file is which in an already downloaded Daz Studio 4 ? Any help much appreciated. Also how does one subscribe to the newsletter ? Thanks.
http://daz.tall-tales-racing.com/resources/tut/basics/B2B_Wn7_DS4_install.htm
  • Miss BMiss B Posts: 3,071
    Hi:
    I'm not exactly sure what your question is about the DAZ Studio files. If you've already downloaded the software, I'm assuming you downloaded a 32-bit version and a 64-bit version, so am I correct in assuming you want to know which of the two you should install?
    If that's the case, it would depend on what your computer's operating system is. I'm not familiar with the different Mac OSes and which are 32-bit and which are 64-bit, but if you are on a PC and running Windows 7 on a fairly new computer, you are most likely on a 64-bit operating system. If you are on an older computer running Windows XP, then you could be running a 32-bit operating system, but you would have to check because I believe XP did come in 64-bit as well.
    Once you determine which operating system you are using, then you should run the appropriate DAZ Studio installer.
    OK, as far as the Newsletter subscription, you should log into your account dashboard, and about half-way down the list of links on the left you should see one that says Newsletter Subscription. If you click on that link the next page you see will have a checkbox next to General Subscription. Check that box and click the Save button and you will be automatically registered to receive the DAZ newsletters.
    Hope that helps. Any other questions, don't hesitate to ask. :-)
  • MarcuseMarcuse Posts: 0
    Hi and thank you for your reply,
    Sorry about that ! I've downloaded three 32 bit .exe versions ok but haven't a clue looking at the list (see link) what does what and which one refers to the original link for the tutorial. Is there also an icon for Studio 4 that goes onto the desktop as well ?
    Thanks.
    602 x 217 - 41K
  • fixmypcmikefixmypcmike Posts: 19,739
    DAZ Studio 4.0.3.47 is the main installer for DAZ Studio and most plugins
    GoZ is a bridge between DS4 and Zbrush. If you don't have Zbrush you don't need to install it.
    3DBridge is a bridge between DS4 and Photoshop.
    Darkside is an extra interface option for DS4, which is more like DS3 and more compact.
    Thanks !
  • IanTPIanTP Posts: 1,329
    You can find some documentation, tutorials etc here - http://docs.daz3d.com/doku.php :)
    Is there an icon for Studio 4 that goes onto the desktop as well ?
    Should be a desktop icon, yes.
