Bake to Transforms or Morphforms to Transforms (.dse) nothing works
Syrus_DanteSyrus_Dante Posts: 983
I have made some poses that I like to save to my library but this time I just want to save the bone rotation values and not all the Pose Control property values that affects the bone rotations.
I thought this is done with Bake to Transforms Shift+B. I select the root node of the Genesis 2 figure and let all settings at the default state in the dialogue Nodes: Root / Propagation: Recursive / Property Path: Pose Cotrols / Property Type: Modifier Pose... Visible Sub-Components only - I all off these setings make sense to me.
But unfortunately the only thing that happens is - the figure pose gets reset to default T-pose. I also tryed the Morphforms to Transforms script that comes with DazStudio in the Utilitis folder and this does the same reset to default T-pose.
I dont understand why this is happening - I must confess its the first time I want to use that funktion but I understand what it should do - let me save my pose preset with real bone rotations and all Pose Control property values at zero.
BTW before you ask - as always I'm using the as far as I konw latest version of DS 4.9.3.166 x64 - Any suggestions will be wellcome.
Post edited by Syrus_Dante on
  • barbultbarbult Posts: 27,607
    Do you have the appropriate check boxes checked?
  • Doesn't work for me either.
    I often use it, then not hope it work as one process, then can bake all pose controller, and morphed shape.
    it depend on, how vendor set those pose morph type correctly,and set group path.
    then I usually bake simple one first, eg foot pose controller, of foot group, or head pose controller of head node. etc one by one.
    or I set un-check visible sub component only.  sometimes it can bake, which I could not with this option.
    the worst problem is, bake transform not work on timeline pose.   it  remove keys on time line. I think. (then It can work, when I only pose on flame zero)
    It still works for me. I tried two simple cases with G3M this morning in 4.9.4.122 Public Beta.
    1) I dialed a bunch of Pose Controls and Baked to Transforms.
    2) I applied a pose from the Big Bill Truck Poses, which uses Pose Controls.
    1 Dial Pose Controls - Bake to Transforms Screenshot 2017-07-15 11.18.12.png
    1780 x 1976 - 431K
    1428 x 1980 - 382K
    1424 x 1980 - 470K
    1 Apply Big Bill Pose - Bake to Transforms Screenshot 2017-07-15 11.37.30.png
    2054 x 1985 - 467K
    2000 x 1985 - 437K
    1979 x 1988 - 493K
