Everything is white
So 4 days ago I tried to render an old scene I created awhile back, when I went to render the scene it came out white. But when I created a new scene it came out normal.  Why can't I render none of my old scenes I have saved?
  • Richard HaseltineRichard Haseltine Posts: 111,806
    Is it rendering in 3Delight? If so you may find that you have a badly compiled Shader Mixer shader - usually restarting DS will fix that but assuming you've tried that go to your Temp folder (which you can find listed in Edit>Preferences, Daz Studio>Prefrences on a Mac) and in that go to the Render>Shaders>Brickyard folder (from memory) and delete the content manually, then try rendering again. If it isn't a 3Delight render, or if that doesn't help, are you getting any error messages?
