Can't see the prop in viewport
I got some prop which is some sort of space rover. It shows up in "content library" and when I click so that it comes into viewport it loads (first can't find textures but I show it the path) but I can't see it. See the picture
What should I do to make it visible? Frist I thought it was too small and tried to scale it up but nothing.
  • Jim_1831252Jim_1831252 Posts: 728
    What happens if you change the viewport to wire frame?
  • Richard HaseltineRichard Haseltine Posts: 111,348
    Please post ful-size screenshots (and use the forum code to resize them in the thread) rather than downsampling them as that makes them unreadable.
    Try clicking on the Frame button (just above the Up Arrow in the group at the edge of your Viewport). If this zooms in to show your prop, it might be loading at a tiny size.
    Same.
    Yeah I did that and still nothing. Nevertheless I clicked on it an I post full frame of it now
    1918 x 1025 - 134K
  • scorpioscorpio Posts: 8,533
    Check in the surfaces tab that opacity isn't set to 0.
    Can you link to where the item is from?
  • kaotkblisskaotkbliss Posts: 2,918
    It could be that Daz is kicking the geometry out due to some read or bone error. Check the log file after you try to load it. I had the same issue with an old poser figure.
