SAVE TO OBJECT FILE
dash2128dash2128 Posts: 736
edited December 1969 in Bryce Discussion
After importing an object from Daz Studio to Bryce, how do I save the object to be used later?
In the Object box, under CREATE?
And how do I go about that?
(I think I did it the wrong way last time. The object wasn't saved.)
  • Dave SavageDave Savage Posts: 2,436
    If you mean how can you save the object into your objects library for use within Bryce, then I refer you back to this post.
    In short:
    Select your object (make sure the whole object is a single group though it can contain sub groups too)
    Navigate to the sub folder you wosh to save your object in to.
    Use the 'Add' button.
    Name your object if it doesn't already have a unique and recognisable name (you can also give it a description on the lower text box).
    A little thumbnail preview will appear in the next blank box in the grid of preview boxes.
