Are there visibility presets for Genesis 3 Female and Male
RKane_1RKane_1 Posts: 3,039
I have visibility presets for many characters but could not find ones to make a hand or foot invisible. Any solutions out there? :)
  • ScavengerScavenger Posts: 2,677
    You can make your own.  4th tab in Property presets. (under save as ->)
  • RKane_1RKane_1 Posts: 3,039
    How do I make it invisible? Just make a Transparency map that is added when the preset is clicked?
    Is there anything else out there already done?>
  • exstarsisexstarsis Posts: 2,128
    With iray, turn down 'cutout opacity' on a surface. You can then save that as a surface preset. Or you can just open up to the limb in the Scene tab and click the little eye to turn it invisible. In properties it's... just 'Visible', under 'Display'.
  • OstadanOstadan Posts: 1,133
    It may be notable that this is a useful technique for fixing a stubborn poke-through of a body part you shouldn't see anyway.  Also, if it's a hand or foot, you can probably just click on the eyeball icon in the Scene tab for the offending limb(s).
    With clicking on the eyeball, I lso have to hit each individual toe. I was hoping there was a checap work around that was instant. I wound up just doing it bit by bit in the Scene pane anyway.
    "Select Children" from the context menu can help make that a little faster.
