3DConnexion SpacePilot Pro problems: buttons do nothing.
I have recently aquired a SpacePilot pro and i'm trying to get used to it, I've managed to reduce the speed from the lightspeed it was moving at thankfully but I cannot get any of the buttons to work in Daz. I've tried remapping them specifically to the controlls in Daz it's self from the selection but still no dice.
Any one have any ideas?
  • GaryHGaryH Posts: 66
    edited May 2017
    I have a SpaceNavigator and it has become an essential tool for navigation - you can just about eliminate the yellow object highlighting entirely, but I digress.  Here are some ideas:
    -  First, I'd make sure you've got the latest 3dconnexion drivers/software installed.
    -  Next, I'd check that you can see the device in DS under Edit->Devices Settings.  You should see a 3D Connexion tab and it should indicate that your SpacePilot is connected.  I use "Orbit Camera" mode.
    -  Next, I'd make sure you've got the DAZ app selected BEFORE you start making button assignments as the settings app is context sensitive - it should say DAZStudio.exe in the dialog box's title bar.
    I only have two buttons on my device but this is how I have them set up (see pic).
    1414 x 1354 - 172K
    Post edited by GaryH on
    I only have two button on my device but this is how I have them set up (see pic).
    I've been considering getting one of these, but was wondering if it was worth having for this software.
  • liquidphantomliquidphantom Posts: 128
    The "official" daz commands just don't seem to work. Might just assign them as keyboard shortcuts.
  • WandWWandW Posts: 2,907
    edited May 2017
    I have an older SpacePilot, which works with the current drivers, and I can't imagine using either Studio or Poser without it.
    One can assign keyboard shortcuts to the buttons within the 3D Connexion software,(I have Ctrl-z and Crtl-y assigned to Number buttons)  but I'm not aware of any keyboard shortcuts to orthographic cameras to assign to the R L T F buttons (which correpond to the QuickView Keys on the SpacePilot Pro) in Studio as I do in Poser.
    Nor am I aware of a comprehensive list of Studio's keyboard shortcuts; I discovered quite by accident that one can change the view mode using the numbers on the number pad.....
    Post edited by WandW on
    I think they are on the number pad.
    edited May 2017
    Chohole said:
    Thank You!    They work well in the SpacePilot button setup. laugh
    And this is what the script gives you (After reformatting)
    DAZ Studio 4.9.3.166 Keyboard Shortcuts
    :Viewport:
    Alt : Orbit Camera
    Shift : Rotate Camera
    Ctrl : Pan Camera
    Ctrl+Alt : Dolly Camera
    Ctrl+Shift : Bank Camera
    Ctrl+Alt+Shift : Dolly Zoom Camera
    Shift+Alt : Focal Zoom Camera
    :Actions:
    , : Previous Tool
    . : Next Tool
    A : Move Left
    Alt+Down : Bottom View
    Alt+P : Snap Level
    Alt+Shift+A : aniMate2
    Alt+Shift+C : Spot Render
    Alt+Shift+F : Scene Navigator
    Alt+Shift+G : Geometry Editor
    Alt+Shift+J : Joint Editor
    Alt+Shift+M : Surface Selection
    Alt+Shift+N :Region Navigator
    Alt+Shift+P :ActivePose
    Alt+Shift+R : Rotate
    Alt+Shift+S : Scale
    Alt+Shift+T : Translate
    Alt+Shift+U : Universal
    Alt+Shift+V : Node Selection
    Alt+Shift+W : Node Weight Map Brush
    Alt+Up : Top View
    Alt+[ : Reset Move Speed
    Alt+] : Reset Rotation Speed
    Ctrl+* : Select Connected
    Ctrl++ : Grow Selection
    Ctrl+- : Shrink Selection
    Ctrl+/ : Invert Selection
    Ctrl+0 :NVIDIA Iray
    Ctrl+1 : Wire Bounding Box
    Ctrl+2 : Solid Bounding Box
    Ctrl+3 : Wireframe
    Ctrl+4 :Lit Wireframe
    Ctrl+5 : Hidden Line
    Ctrl+6 : Wire Shaded
    Ctrl+7 : Smooth Shaded
    Ctrl+8 :Wire Texture Shaded
    Ctrl+9 : Texture Shaded
    Ctrl+= : Select Loop
    Ctrl+A : Select All
    Ctrl+Alt+R : Reset the Camera
    Ctrl+C : Copy Selected Item(s)
    Ctrl+D : Move To Floor
    Ctrl+Del : Delete
    Ctrl+Down :Front View
    Ctrl+E : Restore Selected Item(s)
    Ctrl+F10 : Run To Cursor
    Ctrl+F1 : User Guide...
    Ctrl+F2 : Preferences...
    Ctrl+F5 : Interrupt Script
    Ctrl+F : Frame Selection
    Ctrl+G : Go to Line...
    Ctrl+H : Replace Find Next
    Ctrl+I : Refresh Images
    Ctrl+K : Enable IK
    Ctrl+L : Preview Lights
    Ctrl+Left : Right View
    Ctrl+N : New
    Ctrl+O : Open...
    Ctrl+P : Perspective View
    Ctrl+Q : Exit
    Ctrl+R :Render
    Ctrl+Right :Left View
    Ctrl+S : Save...
    Ctrl+Shift+A : Aim at Selection
    Ctrl+Shift+F : Restore Figure
    Ctrl+Shift+I : Invert Selection
    Ctrl+Shift+L : Convert To Lowercase
    Ctrl+Shift+O :Merge...
    Ctrl+Shift+R :Render Settings...
    Ctrl+Shift+S : Scene...
    Ctrl+Shift+U : Convert To Uppercase
    Ctrl+Shift+W : Close All Scripts
    Ctrl+U : Lock Docking/Undocking
    Ctrl+Up : Back View
    Ctrl+V : Paste to Selected Item(s)
    Ctrl+W : Close Script
    Ctrl+X :Cut to Clipboard
    Ctrl+Y : Redo
    Ctrl+Z : Undo
    Ctrl+[ : Polygon Selection
    Ctrl+\ : Vertex Selection
    Ctrl+] : Edge Selection
    Ctrl+| : Select Boundary
    D : Move Right
    Del : Delete Selected Item(s)
    E : Move Down
    F10 : Step Over
    F11 : Step Into
    F1 : Help Browser...
    F2 : Preferences...
    F3 : Customize...
    F4 : Save Layout As...
    F5 : Run [Continue] Script
    F8 : Save Encrypted Script...
    F9 : Toggle Breakpoint
    Home : Home...
    I : Look Up (Pitch +)
    J : Look Left (Yaw -)
    K : Look Down (Pitch -)
    L : Look Right (Yaw +)
    O : Bank Right (Roll +)
    P : Level (Pitch/Roll)
    Q :Move Up
    S : Move Back
    Shift+A : Zoom Out
    Shift+B : Bake To Transforms...
    Shift+C : Copy
    Shift+D : Delete
    Shift+E : Zero Key
    Shift+F11 : Full Screen Mode
    Shift+F1 : What's This? (Interactive Help)
    Shift+F3 : Find Next
    Shift+F5 : Debugger...
    Shift+G : Directional Gradient
    Shift+H : Sphere Gradient
    Shift+K : Keyboard Navigation
    Shift+L : Geometry Selection
    Shift+P : Paint Brush
    Shift+Q : Draw Stop
    Shift+R : Lesson Record
    Shift+S : Smooth Brush
    Shift+U : Unlock Selected Node(s)
    Shift+V : Paste
    Shift+Y : Symmetry...
    Shift+Z : Zoom In
    U : Bank Left (Roll -)
    W : Move Forward
    [ : Decrease Move Speed
    ] : Increase Move Speed
    { : Decrease Rotation Speed
    } : Increase Rotation Speed
    :Viewport:
    Alt : Orbit Camera
    Ctrl : Pan Camera
    :Actions:
    , : Previous Tool
    . : Next Tool
    A : Move Left
    Alt+P : Snap Level
    Alt+Shift+S : Scale
    Alt+Up : Top View
    Ctrl+0 :NVIDIA Iray
    Ctrl+3 : Wireframe
    Ctrl+A : Select All
    Ctrl+Del : Delete
    Ctrl+K : Enable IK
    Ctrl+N : New
    Ctrl+O : Open...
    Ctrl+Q : Exit
    Ctrl+R :Render
    Ctrl+S : Save...
    Ctrl+Up : Back View
    Ctrl+Y : Redo
    Ctrl+Z : Undo
    D : Move Right
    E : Move Down
    F10 : Step Over
    F11 : Step Into
    F2 : Preferences...
    F3 : Customize...
    Home : Home...
    Q :Move Up
    S : Move Back
    Shift+A : Zoom Out
    Shift+C : Copy
    Shift+D : Delete
    Shift+E : Zero Key
    Shift+Q : Draw Stop
    Shift+V : Paste
    Shift+Z : Zoom In
    W : Move Forward
    Don't thank me, I only posted a tip that Rob passed on to us.
    Well, it seems I will be looking to get one of these soon, then.
  • Cris PalominoCris Palomino Posts: 13,008
    edited May 2017
    Ctrl+Up : Back View
    Alt+Up : Top View
    These all operate on the active (highlighted) viewport.
    Custom actions execute scripts. Custom actions can be bound to keyboard accelerators (shortcuts). Scripts can be written for many things in Daz Studio; it is quite robust already and it is extended to do/expose even more rather frequently. Where there is a will... chances are... there is a way. :)
    Post edited by Cris Palomino on
