GenX2 - from Aiko 4 to Genesis 2 Female?
Fauvist
I'm able to transfer Aiko 4 and the characters made for her to Genesis 1 with no problem.
I fail every time I try to transfer Aiko 4 (or any of the 4th generation figures or characters) to Genesis 2 Female or Male.
Should the SOURCE figure be Victoria 4, or Aiko 4?
With the transfered morphs, do I need to transfer all the morphs of Aiko 4, and Victoria 4, and Morphs++, and the Base Morphs, and the character for Aiko 4's morphs? Or just some of them?
My target figure is Genesis 2 Female.
For the GenX2 SHAPE i am not given the choice of Aiko 4 - only V4 Clone, V4 Legacy, V4 Shape. What should I choose? I'm using Gen 4 Iconic Shapes for Genesis . ( https://www.daz3d.com/gen-4-iconic-shapes-for-genesis ) I have the V4 shape and the A4 shape. Which do I use? Is this considered a Clone or a Legacy or a Shape?
Thanks!
You will probably get answers quicker if you ask here https://www.daz3d.com/forums/discussion/94881/genx2-update-genesis-3-add-on-commercial/p1
Aiko 4 is actually a morph of V4 and her CR2 just loads a pre-morphed version.
Load figure > browse to Aiko 4.CR2. Right click in the transfer window > All > transfer ON for non zero values. Target = Genesis 2 Female
Oh oops. Apparently I mis-read. I thought you were transferring from Aiko 4 herself. If you're trying to transfer using the Iconinc Shapes for Genesis, you want your source to actually be Genesis and to transfer the Aiko 4 morph.
Set the source to Genesis and load a Genesis figure into your scene. Right click the parameters tab and zero the figure, then dial in the morph for Aiko, right click in the transfer window > all > set values to zero. Now right click again > all > get values from figure in scene (this is easier than digging through everything in GenX's transfer window). Transfer the result from this.
