Clear all animations
When I'm done with an animation, I'll select all the animated figures (or items) and clear the animations for each. Then I go back to using frame 0.
Works great except the scene file size still remains quite large. And it takes a while to save the scene.
Is there any way to completely wipe all animations in a scene?
  • wolf359wolf359 Posts: 3,936
    Hi
    Try selecting each figure and choosing >clear figure
    also go to the main timeline and set the number of frames to one and save.
    this should remove all of the animation Data from the scene.
  • TooncesToonces Posts: 919
    Sounds good, thanks for the tips! (mcasual seems to have a script for everything!)
    Hi I have the mcasual script and I am pretty sure it is only for removing keyframes from static objects and not flgure animation.
  • Syrus_DanteSyrus_Dante Posts: 983
    edited May 2017
    Another tip for cleaning up animation frames I guess is set the play range from 0 to 1 in timeline and save the scene again or maybe save a subset with playrange 0-1.
    Post edited by Syrus_Dante on
  • JimbowJimbow Posts: 557
    I use the mcasual Unanimate Total script and it seems to delete all animation values.
    Jimbow said:
    Thanks
     I shall run over and grab that one as well.
