Problem with the "subscriptions" function in the forum Control Panel
In the Control Panel, there is a "view subscriptions" feature which shows all the threads you've posted in. But the links don't actually work.
I've discovered that this is because they contain a rogue question mark. If you delete this, the link works.
e.g.
http://www.daz3d.com/forums/?/viewthread/16207/
Given that it's rather useful to be able to go to your subscribed threads, can this please be fixed?
Post edited by Sertorial on
If you want to trace all the threads that you have posted in, then go to your profile, and click View all posts by this member.
I only use the my subscriptions page to remove subscriptions. no to actually go to them
Precisely my point.
The links in Control Panel > view subscriptions don't work (hence my post). It's because a rogue ? has been inserted. If you remove it, the link works
Hi, same trouble for me, and also using Chohole method to get direct access to threads i've participated in
But what about the threads you just subscribed without posting in it ?
I often subscribe to some thread just to survey their content (commercial announce, helping methods, etc...) but i dont feel the need to post inside, so, how can i get back easily to them later ?
