can modifier in duf override shading domain in dsf?
MistaraMistara Posts: 38,675
can modifiers in duf override shading domain in dsf?
theres seams in g3's back in a deep v,
seams there is difficult to work with crying
would appreciate syntax help angel
making a custom uvs, but i dont see how to separate the shading domain.
tyheart
    also blush
    my way of making the g3m's anatomical geograft compatible with carrara, is to delete the graft section in the dsf,
    if there is a better way, like make the duf ignore the graft section in the dsf yet still read the geometry from the dsf,
    advice would be appreciated,
    thanks!
    graft section is part of the geometry section
  • Richard HaseltineRichard Haseltine Posts: 111,363
    Certain presets will store edited geometry, I assume including changes to surface groups, but it's not something I've tried.
    It's possible to change the AutoHide and graft groups, but not to remove them entirely (without directly editng the file).
  • ScavengerScavenger Posts: 2,677
    Which ones?
  • Does Carrara support geoshells?
    Which ones?
    Character presets, when used to load a new figure rather than to modify the selected figure. Wearables presets, I think.
    frustrating
    reading the duf line by line, dont see anything that looks like a boolean for geograft to non-grafting conforming.
    nothing that doesnt involve editing the dsf
    not ds geoshells
    i heard there are workarounds, smiley
    not solved op yet.  advice request still requested smiley
    when i think i've made progress, 1st test is saving as a character preset, results in dup id errors.
    think i know where it comes from now,
    when putting a lib section in the top part of the duf file,
    for example material_lib, (g3 has 3 mat_lib entries in default duf),
    but then you put a material modifier in the scene section,
    id can't match exactly the id in material_lib section. causes the dup id message
    can manually fix it,
    but then when setting character shape sliders and such,
    save as character preset,
    the file creates it's own id under scene section
    and doesnt always pay attention if the id is already used in the _lib section.
    and other stuck-ness, how to morph inject into a native carrara figure.
    though, pretty sure would has to be a .cbr file.
    what language is ds script?  not python?
    edited May 2017
    DS script is ECMA-262 script (version 5.1), like Javascript.
    Edited to fix messed up versioning
    Which ones?
    If the file type loads an object it will have the chnaged geometry, if not (if it's just settings) it won't.
