Poke Away Question
TooncesToonces Posts: 919
If I already have Fit Control, does Poke Away add anything?
The only thing I can think of -- sometimes fit control doesn't target the exact spot I need to have moved for fixing a poke thru issue.
But I'd imagine Poke Away would have the same problem...though 123 morphs does sound like it targets more 'places' than fit control.
  • Richard HaseltineRichard Haseltine Posts: 111,363
    Fit control adjusts the clothing to fit over the figure, Poke Away can adjust the figure to fit in the clothing. Fit Control does have a nice script to put the moprhs in the clothing, while with the new projected into the clothing element of Poke Away you have to set the morphs on the base, zero them, and go nto hidden parametrs on the clothes. personally I'd get both, funds permitting; if you have to pick one it probably depends on taste whether the Fit Control or Poke Aaway approach is better.
  • TooncesToonces Posts: 919
    Thanks! I wishlisted it.
    A (minor) concern is how the morphs are loaded 100% of the time, potentially slowing the load of a new G3F/G3M figure and increasing the size of the morph list to scroll thru.
    I like how fit control only loads them when specified.
    Any morph product will load its morphs, in the forum of parameter sliders, with the figure - but the bulk of the data, the deltas (changes in vertex position) don't get loaded until the morph is given a non-zero value. The video for Poke Away 2 should still be informative
