How do I access the morphs in the 'data' folder?
rilla
Noob here,
I just purchased Zev0's "Glute and Breast Movement for Genesis" I can't find the morphs? All of this pack's content is installed in the 'data' folder which is located in at "My DAZ 3D Library / data".
I'm not sure where to access the morphs? I loaded in the Genesis 3 Female but can't figure out how to apply the morphs.
Any help?
If you mean this product - https://www.daz3d.com/glute-and-breast-movement-for-genesis then it is for the Genesis figure & therefore does not work with Genesis 3 Female
To use these morphs you will need to load the Genesis figure & I think you will find them under Parameters.
If you are using Genesis 3 then as long as you made your purchase within the last 30 days you can return these & get a refund & then buy the G3 versions instead
https://www.daz3d.com/glute-control-for-genesis-3-female-s
https://www.daz3d.com/breast-control-for-genesis-3-female-s
Are you looking in the Content Library or Smart Content panes? Don't bother, they aren't there. Anything that installs to the /data/ folder will automatically appear directly in the figure's Parameters pane, when you load the figure (in this case Genesis) into your scene. I'm not sure exactly where you'll find them (I don't think I bought that morph set for Genesis) so you'll have to go digging in the Parameters pane.
