Faveral - MICK-Bundle 2
Michael L RogersMichael L Rogers Posts: 141
edited May 2017 in Product Suggestions
Just a request of Faveral. If it would be possible to create a second MICK-Bundle kit that would have 45 degree angles of windows and doors like in the art below I created? As you know, the pieces in your kit are "one full space at a time momemnt" snap togethers, which is great. I can't get the pieces to smoothly connect with a 45 degree angle like I have them in my first picture. You created each of these pieces to move each direction one full space, which is awesome, but could you make it to where they can also move 1/4, 1/3 and 1/2 spaces as well as 45 degree angles too? So if you created a second kit, it would come with these abilities which if purchased, would also add that ability to the first MICK-Bundle kit.
Also you have 2 stair cases in the MICK-Bundle, it would be cool if you could make other stairs that would be the mirror of the stairs that are facing only one direction. I also added 2 other pictures below of smaller and larger stairs that would be super cool as well as balconies. Like your already MICK-Bundle kit, these balcomies would only be for the camera view from inside like everything else you have in that kit. So the view would also be from the inside looking out. Yet, it would look solid as if there is a stunning balcomy to walk out on too.
Thanks for at least reading my ideas. Mike Rogers
3150 x 1772 - 5M
3150 x 1772 - 2M
3150 x 1772 - 3M
Post edited by Michael L Rogers on
  • alexhcowleyalexhcowley Posts: 2,411
    Angled walls and half snap moves sound like excellent ideas to me.  Personally, I'd like to see larger and more ornate roofs, stairs and arches as well.
    Cheers,
    Alex.
  • FaveralFaveral Posts: 416
    Thank you for your suggestions. The stairs and balconies are definitely a possibility. 45 degrees walls are possible as well... other angles might be difficult to achieve...The problem being that to retain the snap ability of the other pieces the angles have to fit in a base square. Instead of a 90 degrees wall I can make 3 30 degrees walls to kind of round off a corner, but this also implies new roofs and ceilings to match. It's doable but will require a bit of work.
  • Michael L RogersMichael L Rogers Posts: 141
    edited May 2017
    Thanks Faveral. Thanks for considering a second kit. I can only imagine how busy you already are. But it would be awesome to have even more stuff to work with since your kits and everything else you create are so adictive. A handful of my art below using some of your products.
    3150 x 1772 - 4M
    3150 x 1772 - 4M
    3150 x 1772 - 4M
    3150 x 1772 - 4M
    The pirate's seaport one is a genuine work of art.  The lighting is amazing.
    Cheers,
    Alex.
  • Thanks Alex
