Transfer morphs from G3f to dress...problems
I am trying to transfer some morphs (some standard and some made in Zbrush) from G3f to a dress so that the dress (that was made for G3f) fits my morphed G3f figure better. I assume I should use Transfer Active Morphs. I have the G3f figure selected in the Scene Tab. However I get an error message saying: "You must selected a figure built using Parametric Joint Parameters, that either has another item "Fit to" it or is "Fit to" another item, inorder to perform this action."
I assume G3f is built using Parametric Joint Parameters and it is selected. The G3f  figure does have another item "Fit to" it, namely the dress.
So, what am I doing wrong?
  • Richard HaseltineRichard Haseltine Posts: 112,049
    Parametric rigging is the old, non-weight mapped. Poser-style rigging. With weight mapped figures morphs set to AutoFollow (in Parameter Settings) are always trasferred.
  • IsaacNewtonIsaacNewton Posts: 1,300
    Thanks, that worked. Also needed to remove/reduce the Smoothing Modifier on the dress, but it did the job.
