Lazy prop enlargement - scale up
Been thinking about applying larger props into some smaller prop builidng interiors.
Is there a way to do this without using the scale tool.  The whole scene goes into alot of different pieces with the tool
Yes, I selected ALL.
I have been playing wiht the sci-fi blast bunker by 1st bastion and thought I would like to put some kibaretto shuttlestar inside and use as temporary hanger
The shuttlestar is too big for placing and launching from inside, and the blast door is too small as it is.
I was thinking if I could enlarge the entire blast bunker by about 1/3 it would be about right.
  • murgatroyd314murgatroyd314 Posts: 1,569
    The problem is probably that each piece is being scaled around its own center, rather than everything being scaled around a single point. The first thing I'd try is grouping everything, then scaling the group.
  • lenwilderlenwilder Posts: 188
    I will try that.
    Thanks
