Help me please - get rid of the floor grid - SOLVED
ThatGuyThatGuy Posts: 797
edited April 2017 in The Commons
Is there anyway to get rid of the grid (the ground)?  When I render my image the grid cuts a straight line into my base object and it makes it look weird.
Post edited by ThatGuy on
  • Richard HaseltineRichard Haseltine Posts: 111,734
    The grid shouldn't render, unless you are using the basic OpenGL mode. Anyway, you can hide it (for the benefit of future readers of thsi thread) from the Viewport option menu - click the lined  button in the top corner or right-click the tab.
  • Is there a way to completely DELETE the floor (so that it doesn't block render regardless of camera location)?
  • I assume you mean something other than the floor drid. If you mean the ground in Iray, there is a draw Ground check box in the Environment group in Render Settings.
  • Silent WinterSilent Winter Posts: 3,962
    edited January 2018
    If you're in iray - go to render settings: Environment: Draw ground - off
    If it's an actual floor prop you're having trouble with - delete it from the scene tab
    Edit: slow loading tabs for me - ninja'd by Richard
    Post edited by Silent Winter on
