Waterfalls
srieschsriesch Posts: 4,243
edited April 2017 in The Commons
FYI, I see "SY Rigged Waterfalls Iray" exists!  Woohoo!  https://www.daz3d.com/sy-rigged-waterfalls-iray   Still installing, haven't had a chance to play yet, but I see there are several different sizes and they include separate spray props as well as the main bulk of the waterfall.
Post edited by sriesch on
  • Peter WadePeter Wade Posts: 1,698
    sriesch said:
    FYI, I see "SY Rigged Waterfalls Iray" exists!  Woohoo!  https://www.daz3d.com/downloader/customer/files#prod_43139  ; Still installing, haven't had a chance to play yet, but I see there are several different sizes and they include separate spray props as well as the main bulk of the waterfall.
    You've given us a link to your product library page which doesn't work for anyone else. I think the one you want is https://www.daz3d.com/sy-rigged-waterfalls-iray
  • srieschsriesch Posts: 4,243
    whoops, thanks, corrected.
  • HorusRaHorusRa Posts: 1,665
    edited March 2019
    Post edited by HorusRa on
  • XyetztXyetzt Posts: 27,546
    Why is it iRay  only?  Or is it just the shaders used?
    cause IRAY RULES! LOL
    you can probably get it to work if you have your own 3DL water shaders
    edited May 2017
    Finally had a moment to try it out.  Since I'm trying to get it to work in 3DL, I tried using the conversion script.  I'm missing something obvious though, because I can't seem to get the opacity working, not sure what I'm missing.  It looks like it should be working... but I'm getting black squares around the outside of each droplet (the droplets are mapped onto numberous randomly angled tiny planes.)  For testing I tried changing the bump and displacement to zero too but that doesn't seem to be the cause either.  What am I missing?
    1023 x 1005 - 685K
  • ArtiniArtini Posts: 10,894
    edited May 2017
    Just an iray render of SY rigged waterfalls and one of its shaders applied to the terrain exported from Bryce to Daz Studio.
    1920 x 1080 - 551K
    Post edited by Artini on
    Just figured out the answer to my previous question.  You have to set the "Refraction Strength" parameter to zero to get rid of the square around each drop.
    edited July 2017
    Just for kicks, here's a random waterfall test, using waterfall 13, plus two copies of the spray for it, rendered in 3DL.  I forget which shader I applied to the body of the waterfall, the spray just used the iray-to-3DL conversion script plus setting the refraction strength to zero.
    343 x 462 - 341K
    edited July 2017
    This one uses one of the waterfalls as the water pouring out of the downspout.  Iray render. I just shrank it down and then lengthened it to suit. It didnt' stretch weirdly when I lengthened it either which was really nice.
    2000 x 1600 - 2M
