Saving my render without shadows
michaelxm_a1dddd836b
Hi everyone; Is it possible to save my .png renders without the shadows. Since they have a transparent background, I can add them to an exisitng photo. But I do not want the shadow in some cases. Also can I make an animation then render each frame in .png? Thank you in advance for any help :)
Shadows depend on the renderer you're using. You can opt out of shadows when using 3Delight or Iray Interactive, but not Iray Photoreal.
If you're using Iray Photoreal, and it's the ground shadows you don't want, go to the Environment tab in the render panel and turn the ground shadow option off (it's located near the bottom).
The main render panel has an option to render an animation to single images.
Thank you, Tobor. Finally, something not complicated.. lol
