smoother circles in spline model room
Evening
I'm doing some panels with cutouts in the Spline model room. The circles aren't smooth look a bit more like they have 6 sides.
I know in the vertex modeler you can hit the plus key to get better resolution, but no go in the spline. Any suggestions.
It also seems like the size of the spline model room effects resolution. Ie the higher percentage = smoother. but you can't change the size of that room.. ;(
So it seems my only possible solution since I am modeling circles in inches in a project that is many feet is to model in a new project and bring that object in?
Thanks for any suggestions, I believe I've has this problem before and resolved it, I just can't remember.
Thank you
8068
figured it out. Under gemotery select surface fildelty increase to400 percent.
B
