How best to use The Harpwood Trail for Daz Studio
Ghosty12Ghosty12 Posts: 2,093
edited April 2017 in The Commons
I just purchased The Harpwood Trail for Daz Studio and find it to be really good but have one big problem what is the best way to load this product without Studio grinding to a halt..  Just not sure what to do as I got it for a project I am working I have plans to use for it, just that I can't navigate around Studio because it is so slow and yet it is am not using much in the way of resources..
Any help would be greatly appreciated thank you.. :)
Post edited by Ghosty12 on
  • TaozTaoz Posts: 10,346
    Try Edit > Preferences > Interface > Display Optimization = Best
  • MasterstrokeMasterstroke Posts: 2,497
    cool thanks ;-)
    BTW, note this on the product page:
    • For Iray renders you must have “Instancing Optimization” set to “Memory” or you risk overloading your system's memory capacity. This setting is built into the Render Settings Preset included in the set but can be found in the Render Settings Tab.
    I tried to render it in Iray but after 50 minutes still nothing had happened. Then I changed the setting mentioned above, and it started rendering after a minute. I'll recommend using the preset in the Render Settings folder as it also gives a great lighting and skydome setup. No problems even with only 8 GB system RAM.
  • Ghosty12Ghosty12 Posts: 2,093
    Cool thank you for the info you save my sanity, thought bought this cool product and can't use it.. Never knew of that option in Studio can now move around the scene without having to wait forever for it to update.. lol
    Only using it in 3DL so not needing it for super renders.. :)
  • alexhcowleyalexhcowley Posts: 2,409
    TangoAlpha's tip on how to get around viewport lag.
    Cheers,
    Alex.
    1920 x 1200 - 409K
    Gosh, I'd forgotten that! blush
    Thank you for the Instancing tip, I was stuck until I read that.
