2 updates fail to install in DIM
greymouser69greymouser69 Posts: 501
Both Fern Lake and IG Iray Essentials - Genesis 3 Female & Victoria 7 show as updates available in DIM but when I download them they both fail to install.
Any ideas anyone?
Edit:  Checked the log but all it says is:
Product failed check, moving to next product : IM00029256-01_FernLake.zip
Install Queue finished in 0 min 0.0 sec.
Product failed check, moving to next product : IM00022269-01_IGIrayEssentialsGenesis3FemaleVictoria7.zip
Post edited by greymouser69 on
  • Sounds like a possible file size issue with the downloads; it's happened with others recently. Best is to notify Customer Service about it to make sure they know.
  • Submitted a ticket
  • nDelphinDelphi Posts: 1,974
    edited April 2017
    I have the same issues with Growing Up for Genesis 3 Male(s) and the Fern lake.
    According to 7Zip, both zip files fail inrtegrity checks.
    Post edited by nDelphi on
  • cgweekscgweeks Posts: 12
    I also have the problem with Growing Up for Genesis 3 Male(s) and Fern Lake.
  • jardinejardine Posts: 1,223
    all of these updates failed to install (via DIM and several deletes/redownloads) earlier today.  now IG iray essentials for g3f & v7 is the only one that's not working.
    j
  • OstadanOstadan Posts: 1,133
    Yes, working now; no information on the readme for what might have changed.
  • Having this same problem with the g3f and v7. Any news?
    the IG iray essentials for g3f & v7 update is still failing to install.
    j
  • same for me
  • PtropePtrope Posts: 696
    edited April 2017
    For me, it's the updates for D|S 4.9 - 32-bit and 64-bit - haven't been able to get them to install for several months from DIM.
    Post edited by Ptrope on
  • CO3DRCO3DR Posts: 163
    If you are running DAZ on Windows 10 in a User Account, you are going to have to exit DIM and run it again with a right-mouse-click to "Run as Administrator". I have to do that every time I install anything "Software" or anything "Carrara". Hope this helps.
    today, tuesday, may the second--
    while at least four of the other files that originally had this problem have been fixed, the IG iray essentials for g3f & v7 update is *still* failing to install.
    j
  • R2ArtsR2Arts Posts: 15
    I HAD THE SAME PROBLEM WITH THE IG IRAY ESSENTIALS.  I JUST WENT AND DOWNLOADED IT MANUALLY AND INSTALLED FROM THE ZIP. BUT, YES TODAY, THE PROBLEM PERSISTED.
    edited May 2017
    yep.  this has been failing for over a week now, i think.
    help ticket submitted--
    Post edited by jardine on
    fixed!
    thanks, daz folks...
    j
