DA's Let There Be Moss -- Iray shaders?
I just got DA's Let There Be Moss product and it seems to do exactly what I expect and want from it. My confusion is in the labeling of the shaders. The shaders under "Shaders/Iray/Vegetation" are labeled as RSL shaders (Renderman Shader Langauge, which is used, as I understand things, by 3Delight) and not MDL (Material Definition Language, which I believe is used by Iray). The Surfaces pane properties editor seems to think that surfaces with these shaders applied are Iray Uber derived and they render fine (some weirdness with lighting that's probably a mistake on my end, as lighting usually seems to be), but I'm worried that I may have a broken install somehow.
Are these RSL shaders that are just working fine in Iray? Should I reinstall to fix something? Is it just an incorrect tag somewhere that I should ignore?
These are the things I think about intead of sleeping. Keeps me off the streets, I guess.
Thanks!
    Probably just mislabeled -- since they show as Iray Uber rather than OmUber they aren't RSL.  Do the 3Delight versions have the same icons?
  • Oso3DOso3D Posts: 15,115
    There's a metadata tag to say what thing it is, probably they just forgot to change it. It shouldn't mean anything so long as it works.
