How do you hide magnets?
UpiriumUpirium Posts: 730
edited December 1969 in Poser Discussion
I'm creating a character with magnets on the face but I cant' figure out how to hide them. They're assigned to the head so whenever I click the head, say to edit things with dials like expression, the magnets show up and I can't hide them ):
  • fixmypcmikefixmypcmike Posts: 19,738
    I'm assuming this is in DS4 -- on the Scene tab there's a column labeled "S" for selectable -- click on that column for the magnets and they become unselectable.
  • UpiriumUpirium Posts: 730
    Nope, Poser.
  • fonpaolofonpaolo Posts: 229
    Select your magnet "Mag X" (where "X" is the magnet's number), on top menu -> Display -> Element Style -> Outline.
    You can do the same simply clicking on the magnet -> right click, a popup will appear -> from the menu -> Element Style -> Outline.
    I say Outline because you can still see the magnet, but this will not cover the object from your point of view.
  • kmw_5213kmw_5213 Posts: 74
    Go into the Properties tabs and turn off its visibility.
    kmw
  • RobertEVRobertEV Posts: 11
    Or select the figure, go to Display - Deformers - Hide All
    That works on the 9mbi clothing, which has a lot of magnets
  • LycanthropeXLycanthropeX Posts: 2,287
    what everone else said, but also if you have the hierarchy window open you can poke out the eyeball by the magnet in that and hide it that way
