Noob Question: Renaming Surfaces
RCDescheneRCDeschene Posts: 2,817
edited May 2017 in The Commons
Can someone quickly explain how to rename a surface zone? For example, I just modded a Genesis 2 Female version Morphing Fantasy Dress to have the skirt and hemline zones split between front and back and I want to rename the "Skirt" and "HemlineTrim" zones as "SkirtBack" and "HemlineBack" respectively.
1600 x 900 - 553K
Post edited by RCDeschene on
  • nicsttnicstt Posts: 11,715
    No idea; i modify geometry in Blender, I find it quicker and easier.
  • Activated the Geometry Editor Tool, go in the Tool Settings Tabs...
    ... if you want rename a group, in the Surfaces listing, double click on the surface group that you want rename.
    ... if you want assign a surface group to an another one, in the Surfaces listing, click on the Surface you want rename (Click on the "+" symbol for select the surface), now right click on the target surface and choice "Assign Selected Faces to group".
  • Richard HaseltineRichard Haseltine Posts: 111,332
    Switch to the Geoemtry Editor tool (Tools menu) and open the Tool Settings pane - you can't rename (as far as I know) but you can select all members of a surface by clicking the + next to it, then right-click on the Surfaces heading and select Create Surface from Selected... Then you can click on the name of the now empty, unwanted surface to select it then right-click on it and use remove seelcted groups.
  • TomDowdTomDowd Posts: 200
    Double-clicking on the Surface name (as listed under Surfaces group) lets you change the name.
    Resurecting this thread because it just answered my question!
    TD
  • Thank you, did not know and I always end up with lots of stupid names from hexagon.
