surface not connecting to bone
alan bard newcomer
hopefully the picture will explain the issue.
just trying to put a door on the cube.
I can get the bone working ... it rotates but the face group is not following....
2 cubes created in daz ... 2 face groups created... exported imported under add geometry in figure setup..
hopefully this is just something simple I'm missing?
1390 x 835 - 213K
After you setup Figure Setup - you have to press the Create button to spawn the new figure.
Now, after selecting the new figure - you have to add a WEIGHT MAP to the surface so the bone knows what to move.
Now you can use a Universal Tool and check if the wall is moving correctly.
You might have small delays in how it moves, but once you save the figure and load the scene again it should probably behave normally.
EDIT:
If you have any issues - tell me and I'll try to help out here.
If you need a lot more information on Rigging and Weight maps in DAZ Studio, I would suggest my PDF guide:
https://www.daz3d.com/the-comprehensive-guide-to-rigging-tools-in-daz-studio
thanks.. we're closer... the base now rotates around it's center and the door rotates around it's bone in the corner.. but instead of the face sitting still and the bone turning .. the door turns but takes the back with it.. so I have to do some more work on the surface selection...
I have no problem with making the cube ... adding the second cube under it and having it work... too bad that exporting doesn't automatically convert sub objects to bones..
and now to sleep
think we've got it....
but now the object with multiple doors will be attempted...
thanks
success ... I had to learn to pick fill by bone selection to get just the door to fill and not all ... but it's working...
the big question becomes...
can I add the doors to the other side working from here?
or basically do I have to have all the separate parts all the doors .. the tailgate ... the liscense plate etc before I perform this ritual?
so far I haven't found a way to not lose the existing bones when I want to add more parts to the base...
but that just requires planning and forethough (and I think I remember what they are.
Thanks for the help .. once I do this a few more times ... it should be ingrained
Well, I came here fashionably late as always - however I see you resolved the issue yourself.
Usually you want your Mesh to be fully ready before you attempt rigging it - just to avoid extra work.
Also it helps a ton to set up your Face Groups correctly (generally one Face Group per bone is useful).
Well, good luck with your work.
I resolved it with the data from your first comment... gave me the start point...
I think what you can select from for the weighting may reflect whether you saved nodes, groups or surface names when you exported..
but thanks for that first comment..
