Props not working in 4.9 - Log included!
Heya everyone!
Just tried to load some props from another store and it said NO WAY!  Just would not load.  Redownloaded the product still no dice.
SO! Here is the log:
2017-04-20 08:25:10.395 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2017-04-20 08:25:10.400 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2017-04-20 08:25:10.400 WARNING: libpng warning: iCCP: cHRM chunk does not match sRGB
2017-04-20 08:25:10.427 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2017-04-20 08:25:22.385 File loaded in 0 min 0.0 sec.
2017-04-20 08:25:22.385 Loaded file: Easel 01.duf
2017-04-20 08:25:22.461 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2017-04-20 08:25:32.366 File loaded in 0 min 0.0 sec.
2017-04-20 08:25:32.366 Loaded file: Canvas White.duf
2017-04-20 08:25:36.883 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
2017-04-20 08:25:39.309 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2017-04-20 08:25:44.015 File loaded in 0 min 0.0 sec.
2017-04-20 08:25:44.016 Loaded file: Easel 01.duf
2017-04-20 08:25:44.083 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2017-04-20 08:25:49.768 File loaded in 0 min 0.0 sec.
2017-04-20 08:25:49.768 Loaded file: Easel 01.duf
2017-04-20 08:25:49.835 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2017-04-20 08:26:06.879 File loaded in 0 min 0.0 sec.
2017-04-20 08:26:06.879 Loaded file: Canvas White.duf
2017-04-20 08:26:06.947 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2017-04-20 08:56:32.935 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
2017-04-20 09:24:53.517 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
2017-04-20 09:53:16.101 File loaded in 0 min 0.0 sec.
2017-04-20 09:53:16.101 Loaded file: Canvas White.duf
2017-04-20 09:53:16.174 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2017-04-20 09:53:23.950 File loaded in 0 min 0.0 sec.
2017-04-20 09:53:23.950 Loaded file: Easel 04.duf
2017-04-20 09:53:25.537 WARNING: cloud\dzcloudtasknotifier.cpp(178): peer performed orderly shutdown errno=0
2017-04-20 09:53:45.877 File loaded in 0 min 0.0 sec.
2017-04-20 09:53:45.877 Loaded file: Palette 05.duf
2017-04-20 09:53:45.953 WARNING: libpng warning: iCCP: known incorrect sRGB profile
Any of that make any sense? Is there some sort of batch to convert 4.8 props to 4.9?
My short term solution is to use the Poser version of the product, but that seems silly all things considered.
Thanks! - Gazukull
  • Richard HaseltineRichard Haseltine Posts: 112,010
    Are you sure you are loading the props and not materials for the props? None of thsoe errros indicate a problem, and the files are shown as loading.
  • GazukullGazukull Posts: 96
    You are correct sir!  This old OutOfTouch product, now that I am reading the documentation says to use the poser format props and under the DS folder "Props" those are materials just for DS.  Seems like, those should really be under materials instead of props...  In either case, reading the documentation was the answer.  Thanks for your help!
    Whoops!
